Y8 intake mani on d15 questions + pictures
Old Apr 30, 2011 | 10:18 AM
Canadian_EF's Avatar
Default Y8 intake mani on d15 questions + pictures
converting to mpfi on my 89 DX using an auto Y8 manifold.
where do these things go?
PS. FITV is mounted i just took it off for the picture.
Old Apr 30, 2011 | 11:53 AM
jlicrx's Avatar
Default Re: Y8 intake mani on d15 questions + pictures
1st picture - IACV - nipple on left - connect hose to nipple on coolant pipe which runs from water pump to thermostat housing - just below intake manifold - nipple on right - connect hose to FITV on bottom of throttle body (nipple toward firewall)
2nd picture - connect hose to FITV nipple closest to front of car
3rd picture - don't use any of that stuff - use MAP on top of throttle body - use purge control solenoid that is mounted on the fuel rail - black thing on right of picture #4 - connect hose #7 that is now going from charcoal canister to the firewall mounted purge, to the nipple in the yellow circle in picture #4
4th picture - purple circle - fuel pressure regulator - hose on bottom is the return line to the fuel tank - connects at the firewall over next to the brake booster - yellow circle, see above
since the Y8 intake manifold doesn't have an Intake Air Temp (IAT) sensor, you will need to add one
Old Apr 30, 2011 | 03:19 PM
i have an iat i'm adding to the intake arm, all good.
what line should i use to connect the purge to the charcoal canister? i can't get the regular small black line to fit onto the purge nipple.
Old Apr 30, 2011 | 03:27 PM
freezy's Avatar
im also about to do the dpfi to mpfi conversion. good luck with it.
95civiclxx
Feb 8, 2011 09:53 AM
thebleek
Sep 4, 2008 01:43 PM
4dek
Apr 12, 2008 01:29 AM
stivic
16
Jul 22, 2007 04:02 PM
