trying to get my aem ems to work
I was wondering if there is anything special you have to do to get the computer to read the ecu? I plugged the ecu in to the car, conected it to the laptop with a serial to usb conector, turned the key on, but it says its not able to contect to the ecu. Am i doing somthing wrong?
Is there anywhere I could get a base map made for my setup?
golden eagle sleeved b18 block (81.5mm)
stock gsr head
precision 6262 with the billet wheel
44mm tial wastegate
aem 3.5bar map sensor
1200cc RC injectors (with a resistor box)
skunk 2 intake manifold
stock gsr head
44mm tial wastegate
Check your serial to usb adapter to ensure it is working properly.
(Look in the windows device manager)
If you can't figure it out, contact who ever you bought the aem from for tech support or aem tech support directly.
stock gsr head
44mm tial wastegate
stock gsr head
44mm tial wastegate
I found the problem. go to "ecu" at the top, go down to "connection port", then make sure serial in selected. Mine was on usb and it wouldnt work lol. Easy fix thankfully.
thanks everyone for the help.
malaya
Jan 2, 2007 06:24 PM
