EG outer tie rod ends on DA?
Old Apr 30, 2011 | 06:04 AM
EJ1_CRIS_909's Avatar
Default EG outer tie rod ends on DA?
Well im pretty much just curious if anything. I have two brand new tie rod ends from my 95 civic ex sitting in the garage, and my da needs new tie rod ends. Will the civic ones fit the da without ruining the suspension geometry? Meaning, will it still be able to be aligned and all? Thanks.
Old Apr 30, 2011 | 03:45 PM
Default Re: EG outer tie rod ends on DA?
Anyone?
Old Apr 30, 2011 | 06:16 PM
MD426's Avatar
As long as it fits and will adjust enough. Just pull one side off and test fit it. Leave the lock nut in place so your alignment isn't thrown off much, you will need a new alignment after the new tie rods anyways.
Old Apr 30, 2011 | 11:31 PM
Ya i got ya, i just wanna know if any1 has had first hand experience or kno suspension systems pretty well b4 i start to pull em apart.
Old May 1, 2011 | 12:18 AM
el crapitan's Avatar
main thing you need to look at is the taper of the base of the joint and the length of the threads on the base. if the taper is the same, and the castle nut threads to roughly the same spot that the old one did, you should be ok. just make sure the taper is the same. it would be best to mic it and compare
Old May 1, 2011 | 11:59 AM
Alright cool thanks for the info, ill have to just pull it apart and compare.
another eg
Dec 9, 2015 05:54 AM
BIGef
20
May 5, 2013 03:38 PM
aser1z
Jan 21, 2007 09:49 PM
Groove_D
Nov 13, 2005 11:36 AM
Nextelbuddy
Apr 25, 2005 06:57 AM
