p0420 code
Old Apr 29, 2011 | 03:39 PM
scott_turner's Avatar
Default p0420 code
with a p0420 code how can i tell if it's the o2 sensor or the cat? Car started bogging down, not want to run right.
Old Apr 29, 2011 | 04:04 PM
frankenghia's Avatar
Default Re: p0420 code
I would say the cat needs replacing. How many miles on it? I believe the 02 sensor will have its own code.
Old Apr 29, 2011 | 04:10 PM
Former User's Avatar
Basically, P0420 is only caused by an exhaust leak or a bad cat.
Check whether the cat is clogged.
Old Apr 30, 2011 | 02:56 PM
replaced o2 sensor. cel gone, but car still boggs down and runs like crap. I listen to inj. to make sure they are working. I swapped the spark plug wires from my sisters lx and still same problem. cat is good, and fuel pressure is good. It has autolite platinum plugs in it, would these cause a problem?
Old Apr 30, 2011 | 03:38 PM
grumblemarc's Avatar
The Grumpiest
How do you know the cat is good?
Old Apr 30, 2011 | 04:14 PM
when i removed it i could see light thru it pretty good. plus it did the same thing with no cat.
sidoe
Nov 1, 2008 02:38 PM
nutball72
Aug 10, 2007 03:05 PM
elpiar
May 8, 2005 09:37 AM
Two_K Si
Oct 13, 2004 08:32 PM
