FS: civic and integra parts, b and d series
Old Apr 29, 2011 | 11:51 AM
98GSR-Turbo's Avatar
Default FS: civic and integra parts, b and d series
I have alot of stuff i need out of my way.
Civic Parts:
97 d series motor mounts $40
96-98 civic heater core $50
96-98 civic climate doors w/ actuators $50
92-00 front hubs with calipers and rotors uncut brake lines $50each or $75 both
92-00 rear upper control arms $20
96-98 4 dr tail lights uncracked un scratched $75
96-00 front lower control arms $30
96-00 front upper control arms $30
96-00 power steering steering rack with good tie rods and tie rod ends $100
power steering resevior $15
96-00 civic dash grey $120
96-00 4 dr carper grey $100
96-00 rear seats grey $60 no rips or tears
96-00 4 dr door panels $40 each or all for $100
96-00 4 dr front and rear and quarter glass $75
96-00 4 dr rear deck tray $50
96-00 4 dr rear padded frame $30 each or $50 for both
96-98 cup holder w/ tape player $40
96-98 tape player $20
96-00 Steering column w/ key $60
96-00 sub frame $50 w/ anti sway bar
Turbo Parts:
OBD1 Xenocron ZIF socket'd chipped P28 w/ 4 pin datalog port $150
Moates HuLog $20
2 1/16th (52mm) Auto Meter Ultra Lite -30/20psi boost gauge w/ hardware and backlight socket $35
2 1/16th (52mm) Auto Meter Ultra Lite Oxygen(O2) LEAN, STOICH., RICH narrow band gauge $35
Misc:
Flowmaster 40 series 2.5" inch center to offset $35
94-01 integra AutoMeter dual gauge pod $35
94-01 integra M3 mirrors with L.E.Ds $35
94-01 integra rear trim between tail lights and bumper $25
94-01 integra a/c system minus the drier $75
94-97 integra OEM drivers side bumper light $10
96-97 integra fuse panels, abs computer $20 for all
98-01 integra Extreme Dimensions XTREME rear bumper $60
98-01 integra crystal clear bumper lights $30
96-00 civic coupe drivers door shell (scratch and small ding, looks like a ball peen tap) $30
96-00 civic drivers door harness $25
96-00 civic drivers door lock actuator $20
96-00 civic drivers door handle NH592P $20
USDM pr3 pistons (less 1kmiles) .020" over (81.5mm) $40
90-93 integra cv axle $20
92-00 civic (2) radiator fans $25ea
94+ rear bumper support $35
dc/eg cruise control module $20
dc teg front splash guards $60
99-00 civic 00-01 integra 98-99 2.3CL 98-02 4 cyl accord Xenocron OBD2B-OBD1 conversion harness $60
I think this is everything IF NOT ill be adding more so keep checking in.
Pm me what you want or need and your zip and we will go from there.
Old May 2, 2011 | 06:50 AM
Default Re: FS: civic and integra parts, b and d series
bump
Old May 5, 2011 | 08:16 AM
bump
98GSR-Turbo
Mar 13, 2012 02:30 PM
98GSR-Turbo
Mar 31, 2011 07:39 AM
2oh6civic
May 8, 2006 09:33 PM
