'95 Civic, no crank, no start.
Old Apr 28, 2011 | 03:30 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default '95 Civic, no crank, no start.
The car: 95 Civic LX
The swap: d16y7, obd-1 alternator, i/m, t/b, p06 ecu, converted obd-2 dist
Checked over grounds and wiring, etc. Car will not crank, not even with a jump. Replaced starter with a known good one. Any ideas?
Old Apr 28, 2011 | 03:43 PM
hmonguy918's Avatar
Default Re: '95 Civic, no crank, no start.
check you fuses..
Old Apr 28, 2011 | 03:46 PM
should have mentioned i am competent. fuses, grounds, etc have been checked.
Old Apr 28, 2011 | 03:50 PM
blackedEk's Avatar
ok can u hear the starter turning
Old Apr 28, 2011 | 04:31 PM
no. fuel pump primes, main relay clicks
Old Apr 28, 2011 | 04:41 PM
blackedEk's Avatar
is this the first time your attempting to start the swap?
tell us more, who did the swap, how is the wiring done?
Old Apr 28, 2011 | 05:26 PM
first start. i did the work, not my first swap. wiring is stock b7
BIGef
Sep 9, 2012 05:17 PM
rollinhonda3
Nov 9, 2010 02:25 PM
See Are X
16
Feb 25, 2003 06:46 PM
