'96 Civic: greasing brake pads newbie question
Old Apr 28, 2011 | 10:55 AM
Jeroen1000's Avatar
Default '96 Civic: greasing brake pads newbie question
I'll probably get an award 4 the easiest question ever
Do I use copper paste on the entire REAR surface of the pads or only a bit in the middle?
And 2nd question, do I grease up the 2 'ears' (green arrows on the picture) that slide into the retainer clips, and should I grease up the 'lining' I arrowed (I'd say no because common sense tells me this is too close to the discs for comfort)
cheers,
Jeroen
Old Apr 28, 2011 | 11:40 AM
94EG8's Avatar
Seagull Management
Default Re: '96 Civic: greasing brake pads newbie question
Grease the ears that the green arrows are pointing to, and grease the back side of both pads (you'll want to grease the middle of the inside pad where the caliper piston touches it, and the outside ends of the outer pad where the caliper touches it)
Old Apr 28, 2011 | 11:41 AM
EJ8_Man's Avatar
You only need to apply grease where the pad makes contact with the metal shim
Old Apr 28, 2011 | 12:12 PM
Jeroen1000's Avatar
No shims on the pads on this car (unless you are taking about the pad retainer clips).
So just to make it easy I'll grease the entire backside of both inner + outer pad with a thin layer + the ears.
If it makes any squeaks I could always apply some more.
Thanks for the clear info. I'm all set for the job as soon as my discs and pads get here
tobybul
May 19, 2018 03:55 PM
LSintegra
Honda Motorcycles
Apr 28, 2008 08:17 PM
mrtrinh
Honda Civic (2001 - 2005)
Nov 21, 2006 02:37 PM
Jeff_B
Aug 25, 2004 05:16 PM
nixadm
Jul 3, 2002 11:55 AM
