Fidanza Cv axles?????????
Old Apr 28, 2011 | 10:20 AM
area522010's Avatar
Icon2 Fidanza Cv axles?????????
Was looking around the internet and found these fidanza cv axles. they retail for $330 each. just wanted to see if anybody was using them. if so did you make it on turbo or all motor, and what power you made on them. and what is there customer service like if they break.according to fidanza the description says.
Fidanza CV Shafts are designed for optimum strength and performance. Each CV Shaft has a rating of up to 300 HP. They incorporate outboard cv joints that are 30% stronger than stock joints, as well as a 4340-chromemoly outer joint stub. The cv shafts' center tube is also 30% thicker than standard tubes, and is manufactured from high-tensile steel. Thick, rugged boots are loaded with high-tempeture, high pressure synthetic grease to protect and lubricate the CV Joints. All pertinent shafts include an ABS (anti-lock brake system) ring to ensure the system remains functional on ABS-equiped vehicles
Old Apr 28, 2011 | 10:42 AM
92redhatch's Avatar
Default Re: Fidanza Cv axles?????????
Buy Dss axels they are proven time an time again. 300hp axles for that just use stock axles.
earl
Jun 25, 2008 10:17 PM
prostreetonline
Jul 7, 2006 04:13 PM
ultimatehonda
Nov 7, 2005 07:27 PM
Doom325
Sep 23, 2005 11:24 AM
Tyson
Jan 23, 2003 07:18 AM
