How do I replace the rear main seal?
Old Feb 22, 2011 | 05:39 PM
houstonhulk's Avatar
Default How do I replace the rear main seal?
Does anyone know if the process is the same for a 96 accord with a f22b1?
Old Apr 26, 2011 | 06:59 PM
Default Re: How-to: D16y8 Rear Main Seal
Well, I have finally decided to change the rear main seal this weekend. Just one main thing I forgot to research. How many quarts of oil will I need to refill the transmission? Also where can I find all the torque numbers for every bolt I touch during this job?
Old Apr 28, 2011 | 06:54 AM
Hello?
Old Apr 28, 2011 | 05:36 PM
poorman212's Avatar
Default Re: How do I replace the rear main seal?
Hello, however I left my crystal ball at work today......so
Is this a 96 Accord or a Civic of some year. I'm sure pretty much the same.
Never did say if this was an auto or manual?
So I'm not really sure how to answer the question or questions.
Old Apr 28, 2011 | 06:32 PM
phootbag's Avatar
Step one, invest in a repair manual.
Step two, repair the vehicle.
Old Apr 29, 2011 | 04:41 PM
Thanks
Old Apr 29, 2011 | 04:58 PM
phootbag's Avatar
You do deserve commendation for wanting to perform the procedure "by the book". Most people rate torque specs on the "bap scale".
Grab your impact gun. One "bap" = little bolts that don't really do much.
Two "baps" = medium bolt that if it fell out might make you wonder what could go wrong. Three or more "baps" = very large bolt that if it fell out you'd know it because the car would suddenly explode in a ball of flames.
Old Apr 30, 2011 | 03:32 AM
holmesnmanny's Avatar
People that go by that need three baps upside the head.
Old May 2, 2011 | 05:34 PM
Good news its not the rear main seal. I removed the dust cover before removing the spindle nut and saw no oil on the flywheel. So I proceeded to look on top for the oil leak. Turns out the o ring on the dist. is completely toast, explains why it leaks big time.
hometheaterman
Aug 8, 2015 09:32 AM
supermotothud
Jun 17, 2008 03:31 PM
piggiepigg
Jun 16, 2007 07:27 PM
mondo375
Jun 15, 2006 07:05 PM
nos96f22
Apr 23, 2003 02:33 PM
