stripped out valve cover bolt threads
so i just did a tune up and i noticed that the center valve cover bolt had a lot of dirty oil on it and around it so i removed the bolt to inspect it and there was shavings still in the thread at the top of the thread anyone know of a way to repair the thread or a bigger valve cover bolt to thread in after i tap the threads bigger
You can purchase a Helicoil kit. It includes a tap, and thread inserts along with another tool to place inserts into the piece you are working with. M6X1 is the size you will need for the valve cover bolts. The kit has instructions too.
The valve cover bolts often have a shoulder, that bottom out on cylinder head, just before the threads start. Be careful not to over tighten the bolts when you reinstall.
ShinotakuX
Mar 5, 2008 03:05 PM
