ef blinkers problem?
Old Apr 28, 2011 | 07:04 AM
andyvaj's Avatar
Default ef blinkers problem?
i was wondering if i needed to hook up or have all the headlight plugs plug in.... my blinkers don't work... alll the lights work, except when i turn on the blinkers? fuse is good also... just wondering if anyone knows anything. thanks in advance.
Old Apr 28, 2011 | 07:19 AM
CWBETB's Avatar
Default Re: ef blinkers problem?
The blinkers have a "flasher" relay box, that is your issue I bet. Auto parts stores carry them that will work for your car
Looks like this
Old Apr 28, 2011 | 07:24 AM
andyvaj's Avatar
thanks, i'll check it out.
Old Apr 28, 2011 | 08:13 AM
andyvaj's Avatar
the hazards work and everything, it's just when i got to use the signals it doesn't work. still think it's the flasher relay?
Old Apr 28, 2011 | 10:10 AM
jlicrx's Avatar
probably the turn signal switch on the steering column
Old Apr 28, 2011 | 11:44 AM
///Mathew's Avatar
Check your blinker fluid level... if you need some this is where I get mine:
http://kalecoauto.com/index.php?main...&products_id=6
Old Apr 28, 2011 | 05:13 PM
andyvaj's Avatar
Not the flasher relay.... got a new one and still the same. Gotta try putting in a turn signal switch....heard people saying that it might be a bad hazard switch also....
Mathew....u some funny Guy! No one is as stupid!!
Old Apr 29, 2011 | 05:20 AM
99SiStyle's Avatar
I got JDM blimker fluid. Only problem is that it blinks on the wrong side.
slammed4dreg
26
Nov 16, 2014 04:24 PM
crookson speed
Jan 2, 2014 07:07 PM
LUDEcidDream
Sep 15, 2011 12:43 PM
wseg
Mar 3, 2010 03:35 PM
athan026
Feb 22, 2009 10:33 PM
