86 CRX SI, D16a1 with supercharger, just died and wont start....need help...
Hey guys, I have a 1986 CRX SI, with a built D16A1 and a Jackson racing Supercharger. The car has been converted to OBD1 and tuned on the dyno with ECTUNE. I put about 10000km on the engine last summer with no problems at all. I put it in storage with fuel stabilizer in October and took it out last Thursday. The car started up right away, idled in the driveway for 10 minutes and I made it about 5 miles down the road and it just died.
I had to tow it home. It hasnt started since.
Since then I have checked everything. Checked timing, changed the plugs, changed the injectors, changed the main relay, change the computer, changed the distributor, checked all my grounds, checked for spark, checked for fuel (40 psi at rail), check compression (200psi) etc etc etc. I've been looking all over the forums and the only things everyone has to suggest is the stupid obvious stuff. I'm not new to this, and there must be something different going on.
Something happened here that is very weird. It just all of a sudden died while driving. The car roles over 3 times, fires once and tries to start, but then doesnt stay running. Its almost as through its going to the start up sequence, but then once it fries to start the engine, it wont stay running. It seems to be giving fuel though the injectors to start the car, but then not continuing to give fuel to keep the car running.
I'm looking for a solution to this, and not the normal stuff. I'm looking for any ideas at all, something different that could be causing this. Hope someone out there can help me.
Dancing is Forbidden
Feb 11, 2015 04:19 PM
crx18c1
Mar 19, 2007 09:58 AM
1987CRXSi
Dec 25, 2004 04:29 AM
blakryder1
Sep 11, 2004 10:04 AM
unltdacc12
Jan 20, 2003 09:24 AM
