JDM front headlight replacemnt?
sorry for the newbie question but i just picked up a jdm front for my gsr and i wanted to know if anyone knows which bulb size goes in the first spot closet to the front grill (fog light yellowish color) thx.
http://www.r-spec.co.uk/bulbs/ WILL BE A CLEAR BULB YELLOW LENS IN THE HEADLIGHT
There is a lots of way you can wire it up. You can wire the foglights with a switch ( which is what it should be like) or wire it to highbeams (not the right way but works).
You need to ground it and everything it should have pig tails, hope this helps.
the bulb that it uses is writen on the lens @ the the bottom of all the lights.
the correct way to wire up the fog lights is through a relay to a switch that is fused.
PurpleAccord88
May 11, 2007 02:02 PM
XxSOHCDriVerxX
Jun 7, 2003 12:15 AM
