GSR A/C Line conversion help
I have a 93 Del sol that ive put a 98 GSR into. I put the A/C Compressor from the GSR in the Del Sol and want to Convert the Del Sol to 134A.
My problem is the lines do not fit from the Integra or my old lines from my Del Sol.
so main question I was wondering is if the lines were the same from a 94 or 95DOHC Del Sol and would fit my car AND my GSR Compressor and if anyone has done it this way.
use the stock d-series compressor and lines from the del sol.
you need a CR-V or a del sol VTEC ac bracket to make that a bolt on affair.
do a 134 conversion to the del sol with fittings and proper oil and rec/dryer.
this has been discussed 100000000000000 times - search for answers.
you need a P54 bracket or and p7j and the p7h works as well....and use your d series compressor. the b series wont work with d series line......... makes sure you use the d series bolts to bolt the d series compressor on cause the b series are too short.....
use2bfairladyzguy
Jul 6, 2008 09:33 AM
