Factory crossmember/ tractior bar bolts stripped wtf
Old Apr 27, 2011 | 11:32 AM
effin's Avatar
Default Factory crossmember/ tractior bar bolts stripped wtf
So one bolt on each side of my tractior bar is stripped, meaning i have 2 bolts one on each holding the traction bar up!!!! I know avid makes a traction bar setup that works with the tow hooks etc. i was told that it would be very difficult to retap those holes being that they are very deep in the chassis
This is my solution in my head what i was thinking would be best. Works with tow hooks. please reply with info
http://www.velocityshop.com/product/...c-crx_413.html
Old Apr 27, 2011 | 01:19 PM
zrickety's Avatar
Default Re: Factory crossmember/ tractior bar bolts stripped wtf
there is actually a nut that was tack welded back there, probably fell down in the chassis. i have one that needs this too, i was thinking of cutting a small slot to get at it.
Old Apr 27, 2011 | 01:40 PM
effin's Avatar
really, damn anybody else? thanks for the info
Old Apr 27, 2011 | 04:35 PM
gringo7718's Avatar
I am pretty sure that re-tapping the bolt is not an option. To fix it correctly, you may have to cut an "access" hole and tack weld on a new nut to the inside of the frame rail.
Here is a writeup on a problem that happens to the rear tow arm bolt. The solution is conceptually similar to what they did in this thread. Hope this helps.
https://honda-tech.com/forums/suspension-brakes-54/%5Bfaq%5D-disc-swap-problem-nut-stuck-subframe-1619903/
Old Apr 28, 2011 | 06:52 AM
effin's Avatar
i may just go with the avid traction bar,
alec3369
Feb 9, 2008 09:21 AM
Takumi Fujiwara
Dec 22, 2005 08:44 AM
ICeDoUt
Welding / Fabrication
14
Sep 15, 2005 07:25 PM
BolivianDc2
Sep 28, 2003 07:03 PM
SPiFF
Jul 3, 2001 03:37 AM
