DA trans bracket Q's for B-series swap.
Old Apr 26, 2011 | 06:04 PM
JDMchucko's Avatar
Default DA trans bracket Q's for B-series swap.
Long story short, Im swapping a b16a3 and hydro tranny into my 89 civic, I know I have to run a DA rear trans mount and front engine bracket for my Hasport mounts, My question is can a run a DA rear trans bracket from a automatic trans car? It shows the same part number (50827-SK7-020 )
Anyone? same part number, has anyone used one?
Old Apr 26, 2011 | 10:21 PM
jdmboyef9's Avatar
Default Re: DA trans bracket Q's for B-series swap.
I thought that the auto bracket was different. I remember looking at a junk yard and the auto rear mount and bracket were positioned slightly different...I could be wrong but I do have a spare 5spd one from a 90-93 integra if you need one
Old Apr 27, 2011 | 08:09 AM
JDMchucko's Avatar
I was always under the impression they were different, but like I said every catalogue I've seen shows them with the same number for both transmissions.
anyone else?
Old Apr 27, 2011 | 10:02 AM
Hasport's Avatar
that is the correct part number for that bracket
and it appears it works in auto and 5spd applications
Old Apr 27, 2011 | 10:26 AM
JDMchucko's Avatar
Thanks again, You guys have been very helpful. I also bought the shift linkage from you guys too, What kind of shifter bushings will work? (it came with none)
Old Apr 27, 2011 | 03:08 PM
JDMchucko's Avatar
TTT.
Old Apr 27, 2011 | 03:32 PM
Hasport's Avatar
factory will work in the rear
for the front get a 99-00 civic si
cehcivic15
Mar 25, 2009 02:14 PM
sorrule
Sep 24, 2008 07:36 PM
MrPotatoeHead
Nov 21, 2007 08:41 PM
moosepoop21
May 20, 2007 06:02 PM
Timmay
10
Aug 18, 2004 07:41 PM
