Motul Tranny fluid? problems?
Old Sep 29, 2002 | 07:40 AM
lePetitePrince's Avatar
Default Motul Tranny fluid? problems?
I have just changed to Motul tranny fluid, but afterwards, I heard that it could kill my LSD?? I did a search and most ppl recommend honda MTF. So what should I do now? is there a real problem to it? or just a myth?
Old Sep 29, 2002 | 03:11 PM
Default Re: Motul Tranny fluid? problems? (lePetitePrince)
anyone??
Old Sep 29, 2002 | 04:04 PM
RagingAngel's Avatar
Motul is a fine oil and I seriously doubt it will do any damage...unless you are using some obscenely heavy weight....
in which case it'll likely kill your entire tranny because it is too thick.....
Old Sep 29, 2002 | 05:11 PM
AW's Avatar
AW
Default Re: Motul Tranny fluid? problems? (RagingAngel)
Kevin
I would stick with Honda Mtl. I love Motul motor oil but every brand of non honda oil in my tranny has caused me problems. Tried redline MTL, and it killed my GSR tranny synchros. Tried some other brand, can't remember and it made the synchros grind early as well. Now I use Honda only and have never had any problems. If the Motul you are using is synthetic which is what I suspect it is, it will probably be too slick and the synchros will grind. Still, I have never used Motul.
Anselm
Old Sep 29, 2002 | 09:21 PM
Default Re: Motul Tranny fluid? problems? (AW)
Thanx guys for the head up, I guess I should stick with good old Honda MTL then.
Dam wasted extra $ on those motul..could've used it on
Old Sep 29, 2002 | 11:39 PM
AJ PwR's Avatar
Never have any problems with Motul or Endless fluids in Honda trannies.
Old Sep 29, 2002 | 11:43 PM
B2FiNiTY's Avatar
Default Re: Motul Tranny fluid? problems? (AJ PwR)
I never knew endless makes fluids.
Greg123
29
Dec 12, 2002 05:43 PM
Tommy_Gunns
Sep 24, 2002 01:59 PM
AutoXsi2000
Mar 8, 2002 10:37 PM
EleanoR
Dec 13, 2001 07:54 AM
Ladies Man
Jun 18, 2001 07:07 AM
