Transmission & Drivetrain Gearboxes, Differentials, Clutches
Weird LSD ITR transmission issue???
Old Apr 26, 2011 | 01:54 PM
justincredible1's Avatar
Default Weird LSD ITR transmission issue???
So I just picked up this ITR not too long ago and the transmission only has 45k on it along with the car. I searched for this problem and there is nothing in the ball park. This is the following problems below it has.
- When the car is off it will go into any gear no problem with the clutch pushed in.
- When I start the car and have the clutch pushed in it will not go into gear until the car warms up a little bit.
- Then if I leave the car in a gear all night then I start the car up it does not want to go in neutral, as if it is stuck into that gear or something. I have to keep my foot on the clutch til it warms up a little.
I have no idea what the hell makes it happen but once the car is warmed up, I never have a issue until the following day when the engine is cold. Also the car is not daily driven due to the weather. What are your thoughts?
Thank you,
Old Apr 26, 2011 | 06:37 PM
Aquafina's Avatar
Default Re: Weird LSD ITR transmission issue???
Whats does the fluid look like and what fluid is it? When was it last changed?
Any leaks from the clutch system?
Old Apr 27, 2011 | 03:08 PM
cruizinmax's Avatar
sounds like the clutch is dragging/not fully disengaging.
kelviiv
Sep 18, 2008 05:38 PM
chocolatesk8er10
Jul 25, 2007 11:24 AM
FastReligion
Jul 10, 2006 10:42 AM
erikgsr
Apr 6, 2003 12:03 PM
hybrider
Aug 3, 2002 06:20 PM
