Sohc Zc axels??
Old Apr 26, 2011 | 01:21 PM
panchlow's Avatar
Default Sohc Zc axels??
i bought a car with zc vtec sohc swap..
nd my axels are going out.
idk if its the zc transmission or not. the number on it is
S20 -1233246
would i get the axels off a d16z6? since its similiar or to that motor? or the crx si? or.....?????
oh i have an eg hatch by the way..
need help.
Old Apr 26, 2011 | 01:37 PM
blackedEk's Avatar
Default Re: Sohc Zc axels??
check this out
http://hondaswap.com/civic-crx-ef/ax...mission-86562/
Old Apr 26, 2011 | 01:50 PM
panchlow's Avatar
i jst found
out what transmission i hav.. it said p20 b000
so its an ex/si
Old Apr 26, 2011 | 01:52 PM
94EG8's Avatar
Seagull Management
Any '92 - '00 D-series axles will work fine, they're all the same.
Old Apr 26, 2011 | 01:55 PM
panchlow's Avatar
so i can go pick up axels off a 92 civic si?
with no problem?
1 of my buddy has them. thats y
Old Apr 26, 2011 | 02:11 PM
94EG8's Avatar
Seagull Management
with no problem?
Yep, they'll work fine, Absolutely the only difference at all in '92 - '00 D-series axles is ABS vs non-ABS, even then you can use ABS axles on anything, if you use them on non-ABS car the ABS wont work. Automatic and 5 speed axles are also the same.
91tahitian.si
Nov 30, 2016 09:11 AM
88EF4dr
Jul 12, 2011 06:42 AM
repingjdm
Jul 25, 2010 08:06 PM
circapunk
Apr 9, 2008 06:09 PM
underage
10
May 17, 2004 09:47 AM
