Gsr Motor Build
Old Apr 25, 2011 | 09:01 PM
OrangeTeggy's Avatar
Default Gsr Motor Build
This is what I have so far, just wanting to make sure I am not missing anything.
Here is my build/ what I have collected
Gsr Head
Blox Type B Cams
Blox Dual Valve Springs
Blox Retainers
Oem Valve Stems
Skunk 2 Cam Gears
Aem Fuel Rail
440 Rc Injectors
Skunk 2 Pro Series Intake Manifold
Aem V2 Intake
81.5mm Cometic Head Gasket
Skunk 2 Cam Seal
Arp Head Studs
68mm blox throttle body
Hy Tec Rep Rage Header
Block
81.5mm Bore
Je Pistons 11:5 to 1 Compression
Eagle Rods
Stock Gsr Crank Micro Polished
Acl Race Bearings
Oem
Type R Oil Pump
Water Pump
Oil Pan Gasket
Oil Pan Pick Up gasket
Valve Cover gasket
Rear Main Seal
7.5 Fidanza Fly Wheel
OEM Exedy Replacement Clutch
Tuned on S300
Will use nitrous at the track.
What numbers do you think I will get with this? Am I missing anything? Also the motor that I will be using was sitting for awhile should I get new oil squirters?
Any help is appreciated this is my first motor build just wanting to have everything before I take it to the shop whose building it
Old Apr 25, 2011 | 10:29 PM
UncleD's Avatar
Default Re: Gsr Motor Build
Read forum rules and look around. Your questions are already answered.
OrangeTeggy
Mar 8, 2011 07:46 AM
x still jaded x
Sep 7, 2010 05:19 PM
Hagakure
Northern California (Sales)
Oct 5, 2008 03:26 PM
official_del-sol
Sep 3, 2008 04:07 PM
Muckman
Jul 26, 2004 08:04 PM
