newly purchased 91 Si...window question
I recently purchased a 91 Si and I am new to these cars. It does nt have power windows though, it has manual windows. My passenger side window regulator was broken when i recieved the car and I pulled one out of the junkyard. But, my issue is that I am in need of the tabs at the bottom of the window which attatch the glass to the regulator, and I'm not sure where I would be able to get them.
I've looked on the dealership catalog online and it says that the windows/tabs are sold as an assembly, but my other issue is that I'm not sure which window I should get because I bought a set of windoewws from a friend of mine who said he had them on his old EF but they are slightly more rounded out than the ones I have and the tabs are differently placed. Where would I possibly be able to get the correct window that I need and/or the tabs to line up the window that was originally in the car and bolt it up to the new regulator?
You need a new window from a 90-91 civic 2dr hb. Also make sure that the regulator you purchased is from the same year. The older 88-89 models are different and will not work. And of coarse 4drs are completely different.
But like I said Si, DX, STD civic 2dr are the same 90-91. Also none of the hb's came with power windows in the USA.
^^Thank you very much..thats good to know, there's a chance I pulled the window regulator from the junkyard out of an '88 lol thinking all of them were the same.
As far as the window itself being from a 90-91 hatch, the trim level does not matter does it?
