B Series Head Work PNP
Hello Guys,
I will show the work i made this weekend.
Is for B18C Bore 81.50 CR 11.7, i dont have machines to test the flow or capacity but check the pics and tell me something :p
looks to me that it's been cleaned up and knife edge as far as i can see from the pics. the exhaust port exits looks big, did you gasket match it? looks like the roof of the exhaust ports been raised a little bit. Which part in the IN port did u spend the most time on?
I cant test the flow because i dont know if have this machine in my country LOL.
I only polished the Intake and Exhaust Ports with Knife edge dont open more...
The part i spend most time is around the valve guides because i dont remove them.
many thanks
many thanks
-Kevin
X2. At least the exhaust ports look a tad large.
I'd also check out your combustion chambers, cant quite tell from the pics due to distance and focus, but it looks like you have a few sharp creases around the valves.
intake looks like its gonna be to smooth and might puddle the fuel on the walls if you can i would try and rough it up a little and i would try and round the intake divider a little more and not keep it a sharp edge. just my .02 even if you dont change anything let us know how it does
JDMDAtehbeast
Mar 16, 2010 08:20 PM
1SlowSi
Welding / Fabrication
Mar 28, 2005 01:55 PM
