ef hatch with ZC/OBD-1 swap bogs when full throttle
Old Apr 25, 2011 | 11:56 AM
OneSloEk9's Avatar
Default ef hatch with ZC/OBD-1 swap bogs when full throttle
So i got a ef that we swapped a ZC into, and converted to OBD-1, so we could get it bar'd. Running a PO6 ecu and it does not show any CEL, and it turns on but when we give it full throttle it bogs out and theres not throttle response. Any ideas because we checked all the wiring and its all legit, completely OBD-1, absolutely nothing wired wrong, multi-point intake, obd-1 injectors and dizzy, checked every single wire and still cannot find the problem. Any ideas at all please help.
Old Apr 26, 2011 | 05:10 AM
dephtone's Avatar
Default Re: ef hatch with ZC/OBD-1 swap bogs when full throttle
Does the car rev alright when you don't put it to the floor?
Have you checked to make sure the timing isn't off?
Old Apr 27, 2011 | 04:36 PM
OneSloEk9's Avatar
the car revs fine otherwise and the timing is perfect we are completely stumped
Old Apr 28, 2011 | 04:40 AM
dephtone's Avatar
Maybe your tps is bad. Check the middle wire (red/blu) voltage. Ignition on, it should show close to 0 volts at no throttle and almost 5 volts with full throttle. If it has some wild fluctuation during the travel, or shorts to ground at any point / full throttle, there is your problem. GRN/WHT is the ground wire.
ghettoda9
Feb 4, 2012 02:50 PM
jtmoney2002
Jul 11, 2008 01:54 AM
boomersz
Apr 15, 2007 09:42 PM
na91hatch
Mar 30, 2006 12:20 PM
I8ayellowcrayon
Apr 3, 2004 07:36 AM
