Gsr Head and Transmission
Contact: PM/Text/Call 731-607-8419 Email: Sickem1@Live.com
Price: 300/400$
I am indeed accepting trades on these items, So hit me up or cash always works.
Both have 137k miles on them.
First up is a stock gsr head. This was pulled off of a motor that spun a rod bearing. The head works perfectly and the block has been disguarded, will come with all 10 head bolts. Still has oem gsr cams. It comes with the intake manifold. 300$
Second up is a usdm gsr transmission. This was pulled from the same swap as the head, never grinded once at high rpm. This transmission is NOT LSD. (as you can see in the pictures, it is very dirty but works great. Will be much cleaner upon sell.) 400$
Also I noticed today that the sticker on the transmission(as you see in pictures) is somewhat "coming off" This was not an attempt to remove the sticker, I guess its just coming off. Its the oem sticker and I have no reason to lie.
Price: 300/400$
ok ill give you that.
but, please tell me as to how the sticker moved itself from the tail housing side where it is normally placed from the factory, over to the bell housing side where it now is covering what would be a vin plate location?
I'm not sure what you "think" you know, but I haven't removed anything and placed it anywhere. The sticker with the "Y80" is where it always is, its just started to tear off but has NOT come off yet. It was just a heads up that it was starting to peel.
*note* I just looked at the picture, and it may look like it is not in its right place, but it IS in the factory spot and is NOT covering anything. This is a pre 98 transmission, it did not come with vin numbers.
*Updated Pics*
I went outside, here is too show how far the sticker will come down, and its placement. The sticker is NOT removed, I just wanted to let the future buyer know that its starting to peal.
abusedvtec
Aug 4, 2009 12:17 PM
