Toe/Alignment Issues with KSPORT Coilovers installed
I recently lowered the car with Ksport coilover kit and now sits with zero fender gap, which is about a 3inch drop all around. Unfortunately my toe is very inward and I have already maxed out the steering rods to correct the toe issue as much as possible but im still around 2.1-2.3 in the front
Question: Where can I get a front TOE kit to be able to zero my toe out completely so I don't go through tires every 6 months
Car info: 2005 Civic Hybrid Sedan, 16x8 xxr 501 w/ 185/55r16 stretch tires & rolled fenders
You'll want to get some flipped tie-rod ends. The angle of deflection is pretty high, when the car is sitting that low.
You'll also want to consider buying tires that fit safely on the wheels you've chosen, or some wheels that fit the tires properly. That combination is extremely dangerous.
Eibach95Civic
12
Aug 20, 2003 03:40 PM
