4spd tranny on a D16Y8?
Old Apr 25, 2011 | 10:29 AM
stylez vangundy's Avatar
Default 4spd tranny on a D16Y8?
is it possible people were telling me it wasnt?
i want to know if it bolts right up
please help !!
Old Apr 25, 2011 | 10:33 AM
Default Re: 4spd tranny on a D16Y8?
bumppppppppppp
Old Apr 25, 2011 | 10:40 AM
94EG8's Avatar
Seagull Management
as long as it's an '88 - '91 4 speed then yes.
Old Apr 25, 2011 | 11:12 AM
but the d16y8 didnt come out in 88-91
thats why im wondering
Old Apr 25, 2011 | 11:21 AM
94EG8's Avatar
Seagull Management
I know, but the bell housing bolt pattern is the same from '88 - '00.
Old Apr 25, 2011 | 11:24 AM
oh gotcha' thank you sir lol
Old Apr 25, 2011 | 06:22 PM
bump any other opinions ????
Old Apr 25, 2011 | 06:29 PM
jdmboyef9's Avatar
What other opinions are needed? My opinion is that 4spd sucks and is a waste of time you might as well get a 5spd tranny.
What he was saying above is that sohc transmissions have the same bolt pattern from 1988-2000.
The real question is what are you planning on doing with the D16Y8? are you putting it into your 4spd STD civic? If so you have to swap the post mount on the engine, clutch and flywheel from your exact year tranny, and a bunch of wiring to convert from DPFI-MPFI plus VTEC...
Old Apr 25, 2011 | 06:32 PM
4spd is cable and the d16y8 came with a hydro tranny would this be a problem ?
Old Apr 25, 2011 | 06:33 PM
idk what a STD civic is lol but i was gunna do it to a bubble or ek
Old Apr 25, 2011 | 06:38 PM
sanimalp's Avatar
$cat /dev/urandom
If you are running the transmission in an EF, then no. If you are trying to run the 4spd in a 92-2000, then yes.
In case it matters, I will also confirm that 88-2000 d series transmissions will bolt up to nearly all d series engines in that range. The only trickiness is the flywheel contact surface area on the 88-89 which is easily remedied, and the input shaft spline count which is only a problem on the 88 transmissions.
If your 4 speed is from an 89-2000, then it will bolt up to the y8 with no problem. if the trans is an 88, then you probably have some parts to buy to make it all work.
Old Apr 25, 2011 | 06:53 PM
im spanish can you dumb it down lol but na im really confused
Old Apr 25, 2011 | 06:56 PM
jdmboyef9's Avatar
The STD stands for Standard or Base Model Civic which is the 4 speed version. The 4spd will work if you are putting it into an 88-91 civic. If you are trying to put a 4 speed into a 92-00 civic then it will not work. Once more you need to provide enough info so that we can help you. If the car you are planning on working on is a 92+ then you are in the wrong thread regardless of the parts that you are working with.
Old Apr 25, 2011 | 06:59 PM
yea i wanted to do it to a 92-2000 but i love ef's i had a crx and a 4door i wouldnt mind getting a hatch so tell me what i need to tell you guys if im getting another ef
Old Apr 26, 2011 | 11:22 PM
jdmboyef9's Avatar
Why simply why, you don't have a car and if for what ever reason you have a 4spd tranny get rid of it. Good scrap metal or paper weight
Old Apr 27, 2011 | 12:57 AM
~sp33~'s Avatar
EFB055
ASHY-ELBOW
Oct 26, 2003 05:52 PM
