Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic LX (Broken alternator bolt)
Old Apr 25, 2011 | 07:14 AM
achall29's Avatar
Default 2005 Civic LX (Broken alternator bolt)
Greetings, Thought I would ask this question to the Honda Community.
My alternator went out last week on my 2005 Civic, while taking the old one out I broke the top bolt off in the bracket. Ive delt with broken bolt ends before by drilling them out or using an easy out. With this one there is no room to get a drill or a elbow drill in there. So I decided to remove the bracket it self and use a drill press. Problem is that the bracket will not come off. Ive removed every bolt including the ones attached to the motor mount. The bracket itself is held up somehow under the timing cover. Could I get any advice on this problem?
Thanks!
achall29@gmail.com
Old Apr 25, 2011 | 06:41 PM
ricanromeo13's Avatar
Default Re: 2005 Civic LX (Broken alternator bolt)
move timing cover and there i think two more bolt i JUST did this on my car last week the bolt was striped so i got a heally coil but yeahhh thats should help
Old Apr 26, 2011 | 05:15 PM
88CRX951's Avatar
I OLD SKOOL
I just did my alternator on my 02 honda civic LX and the bracket wasn't held on by anything on the timing cover.?!? Use the FAQ thread with this link
https://honda-tech.com/forums/honda-civic-2001-2005-78/diy-high-output-alternator-upgrade-1802650/
Old Apr 26, 2011 | 08:45 PM
MindBomber's Avatar
Are you referring to the bolt that attaches to the wing nut used to adjust belt tension, if yes, there is a bracket held on by two 10mm bolts that can be removed and you'll have access to drill it out.
Old May 1, 2011 | 06:22 PM
yeaa
Old May 5, 2011 | 08:39 AM
achall29's Avatar
Thanks~ Done~
PUNJABEE
Jun 15, 2014 05:48 PM
Jimmy
Jun 15, 2010 07:31 PM
dbailey
13
Jan 20, 2010 12:25 PM
Phshorty
Dec 10, 2007 04:48 AM
roadhead
Jul 18, 2006 08:27 PM
