EF8 motor mounts vs 90-91 integra mounts
O.k. im doing a RHD conversion using the front half of a genuine EF8 SIR. but i didn't get the motor mounts... was wondering if 90-91 integra mounts were the same.
i did a search but didnt come up with a solid answer. im runing a LS with a GSR HEAD. LS and trand came from a 91 integra.
PLEASE any word will help THANX
No they are not the same!!!!!!!
I cannot stress this enough! Call me bullshit if you want
I have a real ef9 and bought teg mounts because I was told they will work and the transmission mount will not work. Innovative mounts sells a set of mounts for ef8/9.
http://www.innovativemounts.com/Prod...ductCode=19152
No they will not work on an LHD car. Maybe if it had a B series engine from factory.
The factory mounts for a B series are larger than that of a D series. And the placment of the engine is also different than that of one that is swapped with a B series engine.
I have priced out the factory Honda mounts from a dealership in the UK and they were expensive!!!
Source out any of the parts numbers that jhmed has mentioned if you are looking for new parts, he is right in the money and knows his stuff!!!!! I vouch
Innovative didnt answer my email... i want to replace the stock mount of my EE8 with something stronger, hasport tell me that they dont have the transmission side mount but they have the left side motor and the rear mount just because they are the same of DA integra?
you need actual ef8/ef9 mounts . reason for it is cause the frame rail already sits a little more to the left to accommodate the alternator pully. i know this cause my hasport mounts did not work for ef8 . so i ordered from innovative but be WARNED it took me 3 and a half months to get my mounts. not including all the long distance charges or email's i would not recommend them to anyone. i cant wait for hasport to come out with ef8/ef9 mounts i will buy them right away and swap out my innovative. enjoy the long wait and hassle my friend. but since you are using a usdm chassis you will just need any b-series mounts dude ! <-----
THANKS to ALL for your help im sorry Its been awhile but I can confirm whats different and what needs to be done to get it to work. THANKS.
hard_boiled_EG
Dec 10, 2009 08:39 PM
crex23
Aug 8, 2003 08:11 PM
