1992 Integra Heater Core
Old Apr 24, 2011 | 12:57 PM
DavosDA's Avatar
Default 1992 Integra Heater Core
Im trying to get to my heater core and when removing the dash there are two cables and a wire plug that goes into the back of heater control panel and I can get the heater control panel off or get the the two cables/wire plug behind it. Any suggestions?? PLEASE HELP!
Old Apr 24, 2011 | 02:31 PM
el crapitan's Avatar
Default Re: 1992 Integra Heater Core
i'm pretty sure every time i've ever pulled the dash on these, i've just left the heater controls behind. been awhile though. but i think that's how i did it
Old Apr 24, 2011 | 04:41 PM
fcm's Avatar
fcm
Old Fart
Disconnect the cables at the other end, the plug will go with the dash harness, and the dash, should be no need to remove the controls.
Remove cluster... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Remove console... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Drop steering column... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Remove center sub frame, #6... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Disconnect heater control cables, #14 and #15... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Unbolt dash at the ends... #4 and #5... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Unplug dash harness from chassis harness, door harnesses and rear harness, and remove dash.
Remove duct, #9... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
If you have not already, drain coolant and remove heater hoses, unbolt and remove heater box, #2... http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Split heater box to access core.
Remember where everything goes and reinstall in reverse.94
Old Apr 28, 2011 | 07:37 PM
DavosDA's Avatar
Do have a diagram or a procedure for pulling the heater assembly?
Old Apr 28, 2011 | 07:40 PM
blackedEk's Avatar
not that difficult follow what fcm said, and it should come right off once all the bolts and hoses are disconnected from the heater core unit.
Old May 13, 2011 | 02:23 PM
DavosDA's Avatar
Okay so now i just need to put the coolant hoses on that connect to the heater core on the firewall to the engine but i forgot which hose goes on top or bottom of the heater core inlets. Can anyone send a diagram or tell me where the connect?
Brake_Check
Dec 18, 2013 10:29 AM
eggsi619
Nov 7, 2009 07:39 PM
sixfiveoh
Aug 8, 2009 10:43 PM
JohnD1079
Sep 28, 2007 11:03 AM
haitian1
Feb 17, 2006 01:05 PM
