Dual power wires on single fuse
Old Apr 23, 2011 | 09:44 PM
Natethagreat's Avatar
Default Dual power wires on single fuse
Hey, I was going to go buy a power wire, prolly an 8 gauge or 4 gauge, then i pulled this out of my friends parts car...
I never seen a set up like this, with two smaller wires leading to the fuse holder.
Has anyone else seen a set up like this? what would be the reason to do it this way over just one bigger wire? If this is as good or better then a regular single 8 gauge power wire then imma go and use this. saves me some money lol. Im thinking if it was two 8 or 10AWG wires it would equal something like a 4 or 5awg wire... sound plausible?
Thanks again
Old Apr 23, 2011 | 10:11 PM
98civdx's Avatar
Master Detailer
Default Re: Dual power wires on single fuse
I personally have never seen that before. I wouldn't do that. Why, because it's easy to run 1 single wire to a distribution block, and then 2 wires from there...
On my stereo now, I have 1 4 gauge wire(1 fuse) to a distribution block and then a 4AWG to my 2 channel and a 8AWG to my 4 channel. It's work fine and I have never had any issues with it. Everything has been in the car for about 2 years.
However some will recommend running 2 separate wires from the battery. I won't tell you it's right or wrong to do that, just what I have done.
What amp's do you have? DO you have any of the paper work? Sometimes the company will tell you what gauge you should use.
Old Apr 23, 2011 | 10:27 PM
your knowlage surpasses mine, im not sure what a distribution block is, sorry =[
but, i do know, i have a Kicker zx 400.1. Its a small mono amp for my single 12" Kicker cvr.
Old Apr 23, 2011 | 11:44 PM
98civdx's Avatar
Master Detailer
Basically it does just as it sounds. It takes power from 1 line and gives you the ability to run multiple lines off of it.
Example 1 4AWG going to it, and will let have 2 or more coming out. Sort of what the person did, but a little different.
You can run 2 amps ( or whatever else you want) without having to run 2 amp wires.
I would think that amp could run a 8AWG and be fine.
Old Apr 24, 2011 | 02:37 AM
is there a way i can run these two wires into 1 amp... basically making it act like 1 fat wire that just happens to no be inter-twined?
if not then i'll prolly end up just buying myself an 8awg wire lol
thanks again
Old Apr 24, 2011 | 11:46 AM
98civdx's Avatar
Master Detailer
thanks again
You don'teed 2 for one amp. They likely had 2 amps in the car.
You could take the 1 line out of the fuse and just run the one. However depending on what guage/ type of wire it is.
I also reccomend using name brand kits. A lot of the other no name cheepo brands will sell you a 8AWG kit that has a lot less little wires in side of it compared to others.
I can't find the pics, but I had a comperison of my old wires. 1 no name brand, 1 rockford. Both 4AWG but the rockford cable had A LOT more wires in it.
Old Apr 24, 2011 | 12:53 PM
yeh, i know what your talking about. Thanks a lot man. Im ganna go get another wire, i might keep this fuse tho lol.
kudos!
JDMswagSerf
Dec 26, 2013 06:01 PM
Wazup
Apr 18, 2011 04:04 PM
Liquidgsr
Audio / Security / Video
Apr 15, 2005 10:12 PM
TurbothisLS
Jan 2, 2004 06:02 PM
