Clutch chattering at higher rpms
Old Apr 23, 2011 | 07:33 PM
bk7794's Avatar
Default Clutch chattering at higher rpms
Hey, I have a 1991 honda civic Dx with a 5spd..I got the clutch replaced at a local mechanic.. and it seems like he messed it up. It has been like this for about 20k miles and it has not gone away. It usually does it on uphills because you need more gas to do it, although it seems to be getting worse and I can feel a bit of a vibration at normal take off. If I do clutch and gas at the same time it doesn't chatter..The chatter isn't a little chatter, its shakes the entire dashboard at high rpms...
I hope you guys can help me out, and point me in the right direction of either a new clutch that I will do myself, or transmission or other mounts.
Old Apr 23, 2011 | 10:22 PM
~sp33~'s Avatar
EFB055
Default Re: Clutch chattering at higher rpms
Did the flywheel get machined?
Old Apr 24, 2011 | 08:35 AM
bk7794's Avatar
thats what it says on the receipt. Although there seems to be an odd separation on the transmission mount. like they forgot a bolt or something. I will have pics of it sometime today.
Old Apr 24, 2011 | 11:25 AM
hatchet_honda's Avatar
either they didnt machine the flywheel smooth, adjust the clutch cable, or like you just noticed, forgot a bolt to the trans somewheres.
Old Apr 24, 2011 | 12:16 PM
90efzc's Avatar
Originally Posted by hatchet_honda
either they didnt machine the flywheel smooth, adjust the clutch cable, or like you just noticed, or they forgot a bolt to the trans somewheres.
Sounds safe.
Old Apr 24, 2011 | 01:09 PM
bk7794's Avatar
I have a picture, I just have to upload it. The transmission mount looks odd. Should do it now.
Old Apr 24, 2011 | 04:06 PM
bk7794's Avatar
http://farm6.static.flickr.com/5309/...f147be308e.jpg
http://farm6.static.flickr.com/5142/...6344f6ece5.jpg
Here is the pic of the suspicious transmission mount
Old Apr 24, 2011 | 10:01 PM
no bolt goes in that open hole
Old Apr 25, 2011 | 09:13 AM
bk7794's Avatar
so thats good...atleast. But that would have been simple...do you think a possible tranny mount could be shot?
davefootball123
Honda Civic (2006 - 2015)
Mar 5, 2018 02:28 PM
95ciivicNJ
May 15, 2012 07:15 PM
fernando.
Feb 8, 2009 11:13 AM
_em2_
Honda Civic (2001 - 2005)
Jun 6, 2008 05:13 PM
neopheus
Mar 13, 2005 10:20 PM
