Need help!!! determining what this turbo is. searched
Old Apr 23, 2011 | 06:09 PM
Max McNasty's Avatar
Default Need help!!! determining what this turbo is. searched
im not sure what it is. its a garret m24 .50 cold side and i believe its a .63 or .83 hot side. No nameplate only other numbers i found are on cold side housing 994910 and 9524410m. any help is appreciated
Old Apr 23, 2011 | 09:53 PM
TheShodan's Avatar
Moderator
Default Re: Need help!!! determining what this turbo is. searched
Measure those wheels. Find out where the turbo came from..
Old Apr 24, 2011 | 04:51 AM
So measure the inlet and outlet wheel correct? I need to remove the housings for that I would assume? I have no source to ask where the unit came from
Old Apr 24, 2011 | 07:06 AM
TheShodan's Avatar
Moderator
1)Correct 2) correct again. 3) nope.
Old Apr 24, 2011 | 08:53 AM
JDM B20 EH2's Avatar
Post up some pics of the exhaust side. It should also say a AR some where on it. Usually on the side closer to the center housing under the mounting flange.
Some of the things I am coming up for it say its from a diesel just searching Garrett M24 .50AR
EDIT: By your oil line feed under the front flange bolts you can see some writing. Thats where its goin to say the AR of the turbine side.
Old Apr 24, 2011 | 09:05 AM
jdm it says .63 or .83 hard to tell. i measured the inlet wheel and it is 3" i did not take exhaust housing off as i didn't wanna mess nothing up. on the inlet wheel there was an a stamped on it. if that makes a difference. thank you for all your help
Old Apr 24, 2011 | 09:11 AM
Is it a 3bolt exhaust flange?
Old Apr 24, 2011 | 09:19 AM
4 bolt exhaust mani. but if your asking about exhaust side of turbo it is a v band that was fabbed onto housing so not sure of o.g setup
Old Apr 24, 2011 | 09:24 AM
Old Apr 24, 2011 | 09:41 AM
here they are
Old Apr 24, 2011 | 09:48 AM
now that i look at it it appears to be either 4 bolt or 5 bolt on exhaust
Old Apr 24, 2011 | 09:54 AM
utahturbosohc's Avatar
Looks to me like the same garrett t3/t4, we used on my little brothers car.
http://www.atpturbo.com/mm5/merchant...egory_Code=TBN
Old Apr 24, 2011 | 10:14 AM
Its not the same one. This one is a 5 bolt ford style with a .83 turbine. the 5 bolt in the one you used is a .48ar.
everything I am finding is leading towards it being a stock Diesel turbo.
Old Apr 24, 2011 | 11:18 AM
That isn't the same one we used, my brothers is the 57trim compressor, and ford 5-bolt style .63a/r housing,
Seeing as how you can get the same turbo with a variety of housings, I still think it could be it.
Old Apr 24, 2011 | 12:56 PM
so do you believe its ball bearing? should i get good power from this?
Old Apr 24, 2011 | 01:41 PM
I don't think so. Does it have coolant ports on the chra?
My guess is its journal bearing. We made 413@22psi on a stock b16 with the one I posted above.
Old Apr 24, 2011 | 03:12 PM
not sure what chra is. compressor housing? theres a brass nipple fitting on the cold side
Old Apr 24, 2011 | 03:16 PM
wantboost's Avatar
Who is Mr Robot?
Unless you pull the housings off and measure the wheels, or get the numbers off the Id tag. We can't help you
Old Apr 24, 2011 | 03:17 PM
once again i appreciate all the help and input. ive been in the honda scene for about 8 yrs and this is my first turbo venture so im doing research to learn all that i can before this install.
Old Apr 24, 2011 | 03:20 PM
ok i will take off turbine side. is there anything i should be careful about?
Old Apr 24, 2011 | 04:20 PM
LightningTeg's Avatar
Community Builder
Take off the compressor housing and measure the wheel. Its not gonna hurt anything
Old Apr 24, 2011 | 04:24 PM
wantboost's Avatar
Who is Mr Robot?
Since ^this turbo is used, you might have to man handle the turbine housing to get it off.
Old Apr 24, 2011 | 04:41 PM
Ok so I got it apart safely. Exhaust wheel is 2.5 and intake is 3 inch
Old Apr 24, 2011 | 05:04 PM
TheShodan's Avatar
Moderator
Here's what you need to tell us
LOOK AT THIS DIAGRAM CAREFULLY.
To calculate trim.
Old Apr 24, 2011 | 05:08 PM
after going to the garrett website and using the trim calculation and using 50 ar inducer and 63 ar exducer i got 63 trim. does this seem correct?
