Crx with ls vtec problems. need help
I have a crx with a ls vtec. B16 head with b18a1 block. I have it running. it starts right up and idles fine. I reverse out of the driveway. Put in first and go through all the gears. when i come to a stop sign or red light i put it in nuertal and hit the clutch and it dies. I did the self diagostics test and got this.
Code 7: Throttle poition sensor
Code 9: Number 1 cylinder position sensor
Code 19: A/T lock up control soldeniod
Code 31: ????? no idea
Code 41: Heated oxygen sensor ( dont have one so thats the problem)
Anyone help?
Anyone help?
What computer are you using? Do you have all the sensors plugged in? Everything wired correctly? Was this car already set up for MPFI or was it a DPFI chassis?
