Innovate XD-16 Re-Calibration
Old Apr 23, 2011 | 12:39 PM
slooogsr's Avatar
Default Innovate XD-16 Re-Calibration
Need some quick help... I accidentally performed a free-air calibration on my XD-16 the other day while driving and I can't seem to get it back to normal. I just went out and tried to re-calibrate it by hitting the control button 3x fast and then once when it flashes "CAL".... After I hit the button the last time to do the calibration the display bounces all over the place and does not read "CAL" without blinking like the manual says it should.
Anyone else run into this? Do I need to physically disconnect the O2 sensor from the exhaust to do the re-cal? And yes I am trying to do the re-cal with the engine off....
I tried searching and had no luck...
Thanks and yes I am a bonehead....
Old Apr 23, 2011 | 08:24 PM
met-tuning's Avatar
Default Re: Innovate XD-16 Re-Calibration
it is best to removel the 02 sensor from the exhaust, then plug them 02 sensor from the wideband, then turn the wideband on let it give you an error for about 10 to 15 seconds, turn off the wideband and then plug the 02 back into the wideband still out of the exhuast and let it do a calibration once that is done, do a free air calibration, then plug it back into the exhaust and you should be good to go
Old Apr 23, 2011 | 09:03 PM
joppe's Avatar
I always recalibrate it when decel an flashing 20.9 o2. Pull some revs like 5k and decel then calibrate.
Old Apr 23, 2011 | 09:19 PM
sik96teg's Avatar
The proper way is to pull it out and do a free air calibration so the calibration is dead on. The decel option is pretty smart and pretty lazy, lol.
Old Apr 23, 2011 | 10:13 PM
joppe's Avatar
I have allways get good result with that way. If i push any gas it when calibrating decel it gets wrong calibration and then the gauge is really crazy and values are not steady. I remember i got this way from some innovate manual or forum. I have been using lm1 / xd1 / xd16 5 years. Still same lambda and engine is my 3rd or something lol.
Old Apr 24, 2011 | 04:20 AM
slooogsr's Avatar
Thanks guys... I'll give the lazy shot a try first since I don't feel like getting under the car unless I have too....
Old Apr 24, 2011 | 07:41 AM
joppe's Avatar
My lambda is easy to take off so im gonna remove it and do real free air calibration to see if there is any difference. Car is now running open loop all time with crome gold.
specialone70
Feb 26, 2020 05:29 PM
itsrooster
15
Aug 24, 2013 04:15 PM
Ryan Detwiler
Feb 14, 2013 01:27 AM
scartail
Jun 19, 2005 03:11 PM
B16A1-EF9
Jul 31, 2001 11:02 PM
