Liquid gasket for the block coolant drain...
Old Sep 28, 2002 | 10:28 PM
Tommy_Gunns's Avatar
Default Liquid gasket for the block coolant drain...
Can I use Hondabond for the block coolant drain bolt? How much should I apply?
Old Sep 28, 2002 | 10:32 PM
uNF$@#!'s Avatar
Default Re: Liquid gasket for the block coolant drain... (Tommy_Gunns)
use some silicon.
you can use whatever you want. hell, you can use jb weld if it suits you
its just to ensure there isnt a leakage.
Old Sep 28, 2002 | 10:40 PM
Default Re: Liquid gasket for the block coolant drain... (Soup ****)
I don't want to put something in there that will eventually come off and enter the coolant system. I think I'll use hondabond since I have it lying around.
Just apply even coverage on bolt threads, right?
[Modified by Tommy_Gunns, 1:41 AM 9/29/2002]
R_yd's Avatar
sure can...you dont have to apply a lot, just enough to seal it around
Old Sep 28, 2002 | 10:47 PM
Default Re: Liquid gasket for the block coolant drain... (Rspool)
BTW - I have a block heater instead of the normal drain bolt. Do I just unplug the block heater and turn counter clockwise? What size socket do I need?
Old Sep 28, 2002 | 11:06 PM
tonyxcom's Avatar
I would use thread sealer instead. You can get it at pepboys for 4 bux. Loctite brand.
Old Sep 29, 2002 | 07:29 AM
Extreme's Avatar
No sealant, there is an 28mm aluminum crush washer 90401-PR4-000 used.
xiaogou
Sep 15, 2006 07:09 PM
Copy Cat
Oct 25, 2005 02:13 PM
Paprika
16
Dec 11, 2004 12:38 PM
HoNdAeX11
Jul 16, 2002 04:32 AM
