high compression throw off air/fuel ratio???
Old Apr 23, 2011 | 08:41 AM
99_EM1's Avatar
Default high compression throw off air/fuel ratio???
so here's the deal...will be running b16a2 head with b16a block with ctr pistons.....with basic bolt ons...now my question is will running the higher compression throw off my air/fuel ratio running the oem b16A2 ecu? and dont tell me to get it tuned if im scarred obviously i know that...making it simple...will it throw it off or no when running it? thanks n lmk
Old Apr 23, 2011 | 08:56 AM
evilclown312's Avatar
Default Re: high compression throw off air/fuel ratio???
Do you mean is it going to be able to be read properly? If so then yes its still going to be accurate.
Old Apr 23, 2011 | 09:27 AM
ReDHaTcHyGuy's Avatar
yea its going to be off, the stock ecu can only compensate for so much change from stock
Old Apr 23, 2011 | 11:25 AM
99_EM1's Avatar
so with the higher compression in a b16a than the b16a2 block the air fuel ratio will be richer or leaner with my b16a2 ecu???
Old Apr 23, 2011 | 11:29 AM
hon2984's Avatar
yes it will.....leaner....
Old Apr 23, 2011 | 02:54 PM
ddd4114's Avatar
Why would increasing compression ratio make the oxygen sensor read leaner?
Old Apr 23, 2011 | 04:52 PM
SolScifen's Avatar
i dont see how it would affect the a/f mix at all.
Old Apr 23, 2011 | 07:40 PM
hon2984's Avatar
It doesnt.... the raised compression=more air = the need for more fuel
x2
Short term fuel trim can only do so much before it sets a code....
Old Apr 23, 2011 | 09:32 PM
ddd4114's Avatar
Why does raising the compression ratio induct more air?
Apple395
Mar 5, 2013 01:13 AM
litterbox
Feb 9, 2005 12:43 PM
DJ_SaNdOz
Mar 18, 2003 11:54 AM
Stifler
Nov 27, 2002 01:55 PM
downpipe
Feb 1, 2002 10:30 AM
