b18c oil pump swap?
Old Apr 22, 2011 | 01:08 PM
gsr-t9303's Avatar
Default b18c oil pump swap?
car:2000 teg obd2 p72
engine: jdm b18c obd2
problemil pump,ckf sensor
ok i have asked a couple of members on here if i just swap over the usdm oil pump i can mount my ckf sensor and all would be great. but i got to pump today and it seems to me that i am missing the gear the gives the signal to the ckf sensor. was wondering if i had to get this part? and if there is any other part i need to get, to make it work properly?
Old Apr 22, 2011 | 01:16 PM
gsr-t9303's Avatar
Default Re: b18c oil pump swap?
i do know this oil pump is my jdm one. havent got the usdm yet.
Old Apr 22, 2011 | 01:19 PM
mouab18c1's Avatar
The jdm motor does not support the CKF sensor from what I know. Swap in the usdm obd2 oil pump and you'll be set.
Old Apr 22, 2011 | 06:09 PM
gsr-t9303's Avatar
so all i need is the usdm oil pump?
Old Apr 22, 2011 | 10:23 PM
mouab18c1's Avatar
Yeap, if you run the usdm ecu then you'll need the usdm obd2 oil pump.
ProjectEg93
Apr 28, 2017 04:01 PM
potatointegra01
Feb 2, 2016 04:23 PM
JDM97dc2R
Oct 21, 2011 03:46 PM
ARN1CK
May 30, 2008 06:48 AM
JAMN J
Sep 11, 2007 03:56 PM
