Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Stupid Question Re: 2006 Civic Fuse Box
Old Apr 22, 2011 | 10:31 AM
TIMATOV's Avatar
Default Stupid Question Re: 2006 Civic Fuse Box
OK: I'm clueless when it comes to my Civic and hope someone can pOint me in the right direction. I recently lost the reset code for my radio and was advised I could possibly find the code in the fuse box.
I removed the cover, got the info I needed, and replaced it - but now the car won't start. When I try, all the display lights on my dash illuminate, and I hear a click-click-click noise, so I must have knocked something loose in the process of removing the cover.
Anyone have any suggestion as to where I should look fist?
Old Apr 22, 2011 | 12:40 PM
av911's Avatar
Default Re: Stupid Question Re: 2006 Civic Fuse Box
Dead battery.
Old Apr 24, 2011 | 08:47 AM
bee guz's Avatar
Check the posts on the battery one may be loose or dirty, if you find one that is loose clean them with some sand paper or scrape them with a knife, then tighten the bolt.
You may need a jump start, or better yet put the car on a slow charger for a few hours to bring the battery back up.
If you do charge the battery and find it dead the next day, you might want to see if you left something on that is running down the battery.
If you didn't find anything on you may need to replace the battery, the stock battery's last about 5 years, slightly longer if stored indoors.
Good luck
FrontwheelENT
Aug 15, 2012 07:08 AM
butter99
Jul 27, 2009 11:59 PM
dc2teg2006
Mar 28, 2009 05:31 PM
braypunt
22
Sep 11, 2005 09:10 AM
A08
Feb 15, 2005 08:03 AM
