b16 swap timing off
i have a 90 dx hatch. just put my b16 back in. i tried setting the timing with my timing light and the pulley marks arent lining up. they are on the oppisite side of the timing cover marks where they should be. now i had no prob timing it before. cam gears are lined up, belt didnt slip, piston at tdc. only thing i did was reinstall the dizzy. it only goes on 1 way cause of the offset drive gear so its not backwards. this dizzy came from dist. king and i did notice the rotor has no set screw on it. it isnt even threaded for one and seems to fit a bit loose on the dist. shaft
I currently have the same problem with my distributor king dizzy. I could not get the timing right until i made the adjustment slots bigger.. now I have a code 4 CKP, so I am hoping its the dizzy.
Im having a similar problem with my lsv cant get the timing done.... its bad like my car holds idle at 1300rpms not 800rpms so i cant set the timing and iv checked cleaned messed with my idle screw/tb 20x over its not the ivac or fitv cause i bought a block off for that and idk its bad.... i tried turning my heat on high and lights on high to lower the idle to around 950rpms but thats the closest i can get it to set timing cause i need my car to be at 800rpms but idk its been killing me any ideas any one i rly need the help...
hassan21
Oct 9, 2007 06:35 AM
