HONDA ACURA TURBO PARTS DSM GARRETT
LOOKING FOR EF STUFF And D SERIES PARTS MAKE OFFERS LOCATED IN HOLLISTER CA
ITS A GARRETT T25 TURBO FROM A ECLIPSE COMES WITH AS PICTURED WORKS FIND HAS SOME SHAFT PLAY BUT VERY FUCTIONALY UPGRADED DONT NEED THIS ONE DIDNT BURN OR SMOKE PULLED A FEW DAYS AGO
USED AUTOMETER OIL PRESS GAUGE WORKED FINE
1G DSM ECLIPSE BOV WORKS FINE
VIRGIN PO5 ECU OBD1 92-95 SINGLE CAM NON VTEC U CAN USE THIS ECU TO CHIP FOR TURBO
D SERIES PRE CAT MANIFOLD PERFECT FOR D SERIES TURBO BUILDS
USED REV HARD TURBO MANIFOLD B SERIES HAS SOME RUST ON IT DO TO THE SHED WATER LEAKING IN NOTHING A CLEANING AND HIGH TEMP PAINT CAN FIX
GARRETT T3 A.R.60 TURBO HAS SOME SHAFT PLAY BUT WORKS GREAT DIDNT LEAK OR BURN OIL WHILE IN USE
TURBONETICS DELTA MARK 2 WASTEGATE 38MM WORKED GREAT NEEDS SOME CLEANING UP AND WILL WORK PERFECT AGAIN
THE REV HARD MANIFOLD TURBONETICS WASTEGATE GARRETT TURBO DOWN PIPE B SERIES CAN SEPARATE OR SELL IT TOGETHER
EVERYTHING CAN BE CLEANED UP AND SPRAYED WITH HIGH TEMP PAINT I JUST PULLED IT OUT OF THE SHED EVERYTHING WORKS B4 U ASK AND I NEED THIS STUFF GONE MAKE OFFERS WILL TRADE TO LET ME KNOW WHAT U GOT TEXT 831 524 6753 or pm
bump if viewed thanks
N'viouzEF9
Northern California (Sales)
Apr 22, 2011 08:43 PM
Ignitecivic
Jul 29, 2005 05:52 PM
