o2 code 91 si
Old Apr 21, 2011 | 05:35 PM
nateef9's Avatar
Default o2 code 91 si
i just replaced my o2 this week with my d16z6 swap i reset the ecu twice and still throwing the code. im running obd0.
Old Apr 26, 2011 | 07:28 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: o2 code 91 si
how are you running obd0 with a z6... are you running some 1 wire setup? so much of this doesn't make sense. was this a universal 1 wire or a factory plug style 1 wire? if it was a universal, that is likely your problem, especially if you soldered it, because you shouldn't solder it.
you need to add a whole lot more details for anyone to be able to help you.
racingant
Sep 28, 2005 04:44 PM
ThefirstPACT
Apr 24, 2004 10:45 AM
mugen92acintls
Mar 10, 2004 05:52 PM
