knuckles??
you can use the '90-'91 Civic EX Sedan knuckles to be able to run the larger brake rotors. not sure if the "EK SI" (?) caliper will bolt on. i would figure that the EM1 caliper would bolt on to most double wishbone Honda front knuckles.
you can also use DA knuckles, but the dimensions of the knuckle are a little off (from what I hear).
you may also want to run an EX brake booster and mc. EX master cylinder is 15/16", while other models "EFs" have 13/16" mcs.
to make this simple. op, just get 90-91 EX front brake/knuckles. EX run 10.1 rotors, which is the same as a EK Si. only thing is you wouldn't have to worry about the knuckle being a different length.
Simple SOHC
Jun 11, 2007 06:06 AM
B18C5-EH2
20
Aug 26, 2004 01:39 PM
typeeg
12
Jun 11, 2004 04:04 PM
