Help with valve cover.
Old Apr 21, 2011 | 07:32 AM
Volkspeed's Avatar
Default Help with valve cover.
Ok, so I snapped one of the valve cover bolts. I just had some quick questions on how to go about getting this fixed. By the following picture, is PART A and PART B one piece or two? It is hard to tell if part A screws into part B or if its just one whole part. I am tempted to use a left hand drill bit but want to know you all's opinions before I mess things up even further. What happenes if I loosen up the nut below the bolt? Any help is greatly appreciated.
Old Apr 21, 2011 | 07:42 AM
crx_si-r's Avatar
Default Re: Help with valve cover.
its 1 piece. just remove and replace.
Old Apr 21, 2011 | 08:25 AM
Volkspeed's Avatar
Great, thanks. So do I undo the nut on the lower part?
Old Apr 21, 2011 | 09:22 AM
SI-r rex racer's Avatar
yes undo the nut then head to the local jy and pck em up use either a deep well socket or a wrench they come right out and easy to take out no big deal you can find alot of them at the junk yard most of the time they wont charge you for it
teamrpm2
Oct 31, 2009 12:13 PM
DC206R
Feb 23, 2009 09:38 AM
95_teggygsr
Jan 25, 2009 11:16 AM
AsianEJ1Guy
May 2, 2004 11:54 AM
stripes777
Jul 9, 2003 08:57 PM
