Key Fob wont work!
Old Apr 20, 2011 | 07:34 PM
elliascool's Avatar
Icon3 Key Fob wont work!
its been a long time since my key fob worked but now im trying to see whats actually going on ... since ive fixed my car over and over over the years it has stoped working and yes ive changed the battery and the little light at the top turns on when i press a button but nothing with the car locks happen! might it be an electrical thing in the car or like a fuse or what? how can i reset it or reprogram it ... it wont work at all!
Old Apr 21, 2011 | 08:10 PM
elliascool's Avatar
Default Re: Key Fob wont work!
any help please?
Old Apr 24, 2011 | 02:58 PM
elliascool's Avatar
any help please?!?!
Old Apr 24, 2011 | 05:17 PM
TheMuffinMan's Avatar
He knows where you live!
Guessing you have a 94-97 Accord......If it's OEM, the control box should be on the driver's side up above the interior fuse box. I am not sure on the reprogramming procedure however.
Old Apr 25, 2011 | 01:33 PM
elliascool's Avatar
theres a light blue box above the fuse box under driver side that says WRT on it and some numbers is that it?!?!
Old Apr 25, 2011 | 02:15 PM
elliascool's Avatar
i also checked all my fuses inside and under hood they are all good even my door locks ... so might it be the power door lock actuator located inside the driver side door PDL actuator?!?! i have to replace that then?
single_slam
Mar 6, 2012 10:34 PM
si1992
Honda CR-V & Element
Sep 17, 2011 06:28 AM
SKY350
Acura TSX
Jan 19, 2010 04:44 PM
gabe768
Oct 16, 2009 11:43 PM
hagrid
Nov 22, 2002 08:26 PM
