b16 head
Old Apr 20, 2011 | 11:13 AM
92bseries's Avatar
Default b16 head
my goal is 500 wheel on a poor mans r. the head is kind of older and i was goin to replace the valve seals, but should i replace anything else with it? lma's? valves?
Old Apr 20, 2011 | 11:22 AM
EJ8_Man's Avatar
Default Re: b16 head
You want 500 HP at the wheels, and your asking if you should replace anything on an old B16 head before attempting this?
Old Apr 20, 2011 | 11:33 AM
92bseries's Avatar
covering my bases, i kno a stock head will do it but, double checking everything
Old Apr 20, 2011 | 11:35 AM
EJ8_Man's Avatar
So you're planning a lot of boost? Then also plan for hardened nitride valves, new cams, new springs, retainers, and while you're at it new guides. Also consider a port and polish job.
Old Apr 21, 2011 | 05:43 AM
Red_Army's Avatar
uhh no stock b16 head is holding 500WHP which is ridiculous for a street car. specially turboed.
basically replace everything. also you'll need to beast up your bottom end. do some research.
Old Apr 21, 2011 | 05:50 AM
grumblemarc's Avatar
The Grumpiest
Doesn't seem like you did much research. How did you come to the 500 horsepower number?
Old Apr 21, 2011 | 08:28 AM
Mr. EG's Avatar
Invest in a new set of stock valves or save the old ones if they are still in good shape. Stock valves flow better than any aftermarket valve on the market. I would invest in some dual valve springs and upgrade to at least a set of Gs-R or ITR/CTR cams. If the LMA's made some noise or look worn I would replace them, but if they seem to be in decent shape save yourself the money.
ekhatch110
Northeast (Sales)
Jun 12, 2012 08:11 AM
trickeng
Jul 8, 2009 12:56 PM
atmdc
Dec 5, 2007 02:54 PM
bluegdx16
Feb 17, 2005 06:59 PM
LSR 97
Jan 13, 2002 06:09 PM
