Do I have an aftermarket Intake Manifold? Confused on what's going on
I am looking at my Helm's manual, and my setup seems to be different then illustrated in the manual. My map sensor is located on my Throttle Body and my intake manifold doesn't have the PGM-FI logo on it. I went to a couple junkyards to find some parts and it seemed all the other DA's had a different setup. It seems I'm missing some vacuum lines or something. Can you guys check out my pictures and see if you see something abnormal or missing? 1991 LS btw. Thanks
just discovered its actually a B18B1 rather than a B18A1 haha looks like the previous owner swapped it. My Helms manual isn't as helpful anymore...damn.
I believe it's "connect the dots" - i.e. the one circled in yellow in the top pic connects to the one circled in yellow on the bottom one?
They both connect to the purge solonoid. The one coming off of the IM plugs into the top of the purge and the one coming from the charcoal canister plugs into the bottom of the purge. And you should have a plug dangling from your wire harness in that area to plug into it too. If i were at home, i could post up some pics. I'll try and remember to later if your still lost by then. Hope this helps.
looks like a sloppy/unfinished swap
your air intake has an uncapped bung that is letting unfiltered air into your motor, normally it would be connected to the fresh air inlet on your valve cover. What is the deal with the masking tape on the air intake as well?
it is definitely a sloppy, unfinished swap. The kid I bought it off of was a sketchy idiot. I am getting a hose soon to connect the air inlet from the valve cover to the intake. The tape is to cover up some holes that they drilled in it haha I'm replacing the intake with either a better CAI or just stock intake pretty soon. Just slowly de-ghettoizing this engine
