AL FT: FBP EM1 / ITR Swap / Tein / Mugen / Rays Vesta / MORE !!
SOLD and I miss it !!
I have a '99 FBP EM1 w/ 150,xxx on chassis.
Engine:
-98 Spec JDM ITR Swap (from HMotors)
-OEM Thermostat, Timing Belt, Timing Belt Covers, Water Pump, Hoses (New)
-Alternator and A/C Belts (New)
-NGK Blue Wires, NGK Plugs (New)
-JDM ITR Shift Linkage, Shifter, and Poly Bushings
-Exedy Flywheel and Pressure Plate, ACT Street/Performance Clutch (New)
-Hondata Intake Manifold Gasket (New)
-Mugen Oil Cap
-Innovative Billet 75A Track Motor Mounts (New)
-SMSP Rep Header (New) 2.5” Collector
-APEXi Noir Catback (Flat Black WS2. Real quiet) (New)
-Chipped P28 w/ JHPUSA Conversion Harness, Tuned on Crome
-Downstar Tuckin’ Clutch Line (New)
-Downstar Tuckin’ Inline Fuel Setup (New)
-Go-Autoworks Catch Can (Black AN Fittings/Lines) (New)
-Go-Autoworks Block Plug and Fittings
-Go-Autoworks Rad, Shroud, Slim Fan, Cooling Plate(Mugen 1.3 Cap) (New)
-Custom 3" Intake w/ V-Stack, K&N Filter, and T-Bolt Clamps (New)
-Tucked Headlight Harness
-DIY Headlight Induction (Spare OEM Headlight)
-New Hardware Almost Everywhere (New)
-Dyno'd 186whp/133tq with RMF Narrow Rep Header on Stock Exhaust Should make ~195+whp now !!
Suspension:
-Tein SS Coilovers
-Mugen Font Strut Bar
-ASR Subframe Brace (New)
-CTR 22mm Rear Sway Bar/Si 26mm Front Sway Bar
-PIC LCAs (New Hardware)
Exterior:
-15x6.5 Rays Vesta Wheels (Fresh Powdercoat)
-5mm Front Spcers/10mm Rear Spacers w/ Extended Studs (New)
-VMS Black Lug Nuts w/ Key (New)
-Spoon Style Mirrors (color matched)
-Honda Access Window Visors
-Had dents taken out and buff/wax (3/4/11)
Interior:
-Stock Seats, Wheel, Cluster (Full Interior)
-Alpine Head Unit (Direct iPod Connect)
-Alpine Type R Front/Rear Speakers
-Black OEM Floor Mats (New)
-Freshly Cleaned Carpet
-Ice Cold A/C !!!!
The Bads:
-No P/S
-Has some dings/scratches (its a '99)
-Fogs do not work
Old Header
Engine:
-Mugen Oil Cap
Suspension:
-Tein SS Coilovers
Exterior:
Interior:
-Ice Cold A/C !!!!
The Bads:
-No P/S
-Fogs do not work
Old Header
