Are UCA and Compensator arms the same from DC2 to EK?
Hello,
I was wondering if the upper control arms and the compensator arms are the same as the ones from a 97 Integra to a 99 Civic hatch?
I am in the process of doing the disc swap, and turns out there are lots of seized bolts inside the bushings, so by the time you heat and get them off, the bushings are toast... So are the upper control arms and the compensator arms off a 97 integra the same ones on the 99 Civic hatch?
I know that the Lower Control Arms are infact different because the lengths are much longer on the EK than the integras.
Thanks!
Thanks!
