obd0-obd1 questions
i have a few questions on switching the dpfi-mpfi and the obdo-obd1 conversion for a d16 vtec swap ( first swap)
can i just get a vtec obd1 engine harness and call it a day i already have the jumper and ecu?
90 si tranny or y7 tranny hydro?
can i get some info on dpfi-mpfi
no. you need to do one of the following:
1. convert your stock harness (the one from YOUR car, not the motor) to MPFI;
2. once it runs fine, convert to obd1
or
if you are uneasy about wiring, pm myself or Clipsed, we both make plug n play conversion harnesses.
just getting an obd1 vtec harness will not work, your stock harness needs to be modified to work. plain and simple.
or
bobbyisking
Jul 7, 2008 09:22 AM
aVstAr
Dec 10, 2005 05:08 PM
