96 Accord F22b1 swap f22b2 w/b1 head
Old Apr 18, 2011 | 07:03 PM
RobertDJ's Avatar
Default 96 Accord F22b1 swap f22b2 w/b1 head
OK have an 96 accord ex wagan auto trany, w/f22b1 engine. I had a 96 f22b2 on the ground, decided to rebuild the b2 and put it in the car. Rebuilt the f22b2 new bearings,gaskets,seals, bought poa f22b1 head off ebay used that.
Pulled f22b1 out of car replaced f22b2/w b1 head in car. Timing belt will not stay in place timing keeps jumping. I used an f22b1 timing belt. While covers are off can turn it by crank bolt 15 reveloutions, stays in check. Put it all together, try to start fires up and dies. Pull valve cover,mark on back of cam pulley off about 5 -6 teeth, right about tdc on crank locks up,(inteference). Any suggestions.
Old Apr 18, 2011 | 09:02 PM
GhostAccord's Avatar
Default Re: 96 Accord F22b1 swap f22b2 w/b1 head
Have you already tensioned the belts?
Old Apr 19, 2011 | 06:09 PM
RobertDJ's Avatar
Pulled It apart again re set timing ran it about an hour. all seamed well then it died. I thing the egr valve might be stuck, pull vac hose off idle smoothed out re connected it. Will pull egr valve in am. Thanks for the reply Ghost!!!
Shellbell
Oct 14, 2017 12:06 AM
Aaron Tanner
Oct 5, 2015 11:15 PM
96accord96
Oct 2, 2011 08:00 PM
ram0869
Sep 21, 2004 01:50 PM
89dxhunchback
Dec 28, 2003 11:44 AM
